Rear seat back removal
  • barry
    • 1642
    Tried a search with no success..
    Ok so I'm in the process of taking out my rear back seat and cannot get the back to loosen up. I disconnected all the belt bolts. What do I need to do now.
    I also tried to wedge the seat straight up with a 2x4 and nothing budged are there any bolts from the back that need un-doing?
    Thanks for your help
    Barry
    All the fasteners for the rear seat are on the cabin side. Once all the fasteners have been removed the seat back has to move up to un-hook the catches at the top.
    • barry
      • 1642
      Ok got it. Guess I need to stand on the 2x4 210 lbs should move it, right.. LOL
      • pogiboy9
        • 475
        probably not a push and force, after you remove the bolts and such maybe (i haven't pulled out yet) it's push up towards the back window (vertically?) just a guess :P
        http://www.decal-spec.com
        • Holland
          • Nov 2008
          • 7204
          There are two bolts on the sides with brackets, 10mm I believe. They are back toward the wheel arch. You should see them when the seat bottom is removed. Then lift upward on the seatback.
          Originally posted by DEV0 E30
          • barry
            • 1642
            Ok its out, Ya two bolts behind bolster material. Do not have to remove side bolsters.
            Thanks
            Barry
            • Jean
              • 18228
              Early cars (83-84) also have two more bolts holding the lower seat bottom, these face the backs of the front seats.
