starting situation
  • bzboardz
    • 1096
    starting situation
    Ill let the video do the talking..
    Sometimes the noise at 0:03 last much longer before eventually starting. I think its the starter someone please correct me if im wrong
  • Kershaw
    • 11822
    sounds like a weak starter to me.
    AWD > RWD
    • AndrewBird
      The Mad Scientist
      • 11898
      Either that or a low/bad battery. Might check the engine grounds as well.
      • bzboardz
        • 1096
        sometimes with key in and turn to on position all lights turn on but there is no attempt to turn over, maybe some fault wiring?
        so I put in a new starter and new alt ill see if this helps the situation.
        With the car on im at 13.6v and 12.5 off
