clutch and brake pedal assembly
    Are there differences in the pedal assemblies between '86-89? I looked at an '86 'es' coupe and an '89 vert in the yard today and saw that the vert had two more bolts where it screws in to the steering column. Any help is appreciated. Thanks. :)
    Alex
    -Alex
    I've always been under the impression that the only change was airbag vs. non-airbag.
    1991 318iS
    1992 911
    2006 330i 6-Spd ZSP people hauler
    Gone:
    1989 M3 S50B32, 6-Spd
    1990 325ix 5-Spd
      airbag models have airbag pedal box
      later models had plastic clutch petals and a different box
      early models have metal ones
      early model ones are prone to cracking along the side of the stamped support bracket.
        awesome thanks! Do you guys think I'll be able to use the pedal assembly from an '87 on an '89?
        -Alex
          Yes
            How about this:
            will the pedels off an '90 (airbag) car fit the box in a '89 (non-airbag)?
            1989 cirrisblau-metallic 325i
              Bump
                Originally posted by SpecM View Post
                How about this:
                The brake pedal will. Don't know if the clutch will or not.
                Be advised you will likely still need different bracketry/supports for the clutch pedal (i.e. non-airbag support brackets) even if the airbag clutch pedal fits.
                1991 318iS
                1992 911
                Gone:
                1990 325ix 5-Spd
