Super ETA Head
  • ZiMMie
    • Jun 2004
    • 968
    Super ETA Head
    Jst wondering if its worth anything? got my hands on a complete Super ETA motor. Valve cover looks the same as the 325i's.
    www.stancefactory.com
    • 34839
    I think the block is what's worth money, because you can just bolt on an i head and have it close to the right compression for a cheap 2.7i
    • Jand3rson
      • 37587
      The super eta head is a 325i head, just with single valve springs and a different cam.
      • ZiMMie
        • Jun 2004
        • 968
        im using the buttom end. will the Camshaft have anyeffect in the i Head?
        • Jand3rson
          • 37587
          The block is the same as a standard eta block, Nando. It just has different pistons, those are the only thing really worth anything.
          You'll want to put at least a standard i cam in it, if not an upgraded one.
          • ZiMMie
            • Jun 2004
            • 968
            Wat about the intake mainfold should i use the one from the Super E? since its a 2.7 its prolly bigger than the I mainfold.
            • NickP
              • 257
              The Super E head is the same as the I head - just different valve springs and cam. Some even have the 7 oil journals drilled out. If you have the 7 oil journals I wouldn't bother unbolting the head unless you're putting on a rebuilt head or doing rings or something like that.
              I believe that the super eta intake manifold is similar to a regular eta so you should go with the i manifold / throttle body.
              • swimerskidude15
                • Dec 2004
                • 49
                As josh said all you need to know about the head, and NickP: it does have 7 oil journals. If you want turn the super into a 2.7i by changing camshaft, valve springs, intake manifold and tb. Then change the super motronic to a i ecu. I believe the supereta manifold is even smaller than the eta manifold, but with longer runners.
                • ZiMMie
                  • Jun 2004
                  • 968
                  yea i have the I ECU. can someone explain more about the 7 oil journals?
                  • ZiMMie
                    • Jun 2004
                    • 968
                    ^ bump
                    • ZiMMie
                      • Jun 2004
                      • 968
                      anyone?
                      • EverWiser
                        • Aug 2004
                        • 313
                        From what I understand, the "e" (eta) head only has 5 out of the 7 cam journals drilled for oil flow (I have a bare "e" head in my garage and have verified this for myself). The super eta and "i" heads are the same head with the exception of the cams and springs (single for the s-eta and double for the i). If you bolt on the "i" parts (cam, springs, intake, tb, ecu, etc.) you end up with a stroked 2.7L "i".
                        • ZiMMie
                          • Jun 2004
                          • 968
                          thanx 8) i thought some one ment for me to dril wholes in my block in order for the I head to fit.
