I'm just curious and I know it might not be "worth" the time and money to some of you, but... can you do an s14 swap using the same motor mount arms from the m3? To do the swap I would need the motor and ECU, and I can make other things work probably right? Or would I need an m3 radiator as well? Is the m3 transmission(getrag 265 I think) m3 specific? Or can you use the getrag 260 from the 325i's? Mods, Sorry if this thread is in the wrong place. If it is, please move to the correct location.
Will
Will
