help problem starting car eek
  • rooster
    • Jan 2009
    • 80
    ok so im having problems starting my car 91 325ic, i swapped out injectors 19lb ones replaced the fuel pump thinking it was that but still nothing, if i shot starting fluid in intake manny i get it to fire up & im able to run it but once i shut her down i cant fire her up. i have checked the fuel at the rail im getting fuel, im not sure if a fuse is blown or if its a relay, i seem to be getting the pump to run in start mode, but when it drops into run mode it cuts off, help.. there was white smoke coming up from the bottom but turns out my cats (meow) fucked. speed bumps & lowered cars dont mix lol
    jag
  • wodcutr
    • Apr 2009
    • 2193
    Have you done the stomp test to see if you are pulling any codes? When was the last time you changed your fuel filter? Just becasue you are getting fuel to the rail does not mean it is at the right pressure or consistant pressure. Does the fuel pump run if you jumper the relay to override it? If not, then it is your main relay that is screwed up not the fuel pump relay. Replacing both is not expensive and a good thing to do just for preventative maintenance.
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • rooster
      • Jan 2009
      • 80
      Ok I replaced the main relay & fuel pump relay w my other cars & it hesistates to fire up. I get it to run boggs down & idles a lil high.. I let it idle for a min & it hovers at 1k, drove around like that for couple min shut her down & can't get it to fire up anymore.
      jag
      • wodcutr
        • Apr 2009
        • 2193
        Did it run fine before you changed the injectors? This could be a temp sensor gone bad and the ECU thinks that the motor is cold all the time so is flooding the cylinders with too much fuel. Do you have a bentley? You need to start eliminating things by making sure they test good! It also could be bad AFM, CPS and a few other things too. Gotta narrow it down!
        • rooster
          • Jan 2009
          • 80
          Nope wasn't working right before the injector swap. I should also add that car overheated on me but it turnf out to be a combo of bad house, bad t-stat & belt.. yea she's been a pain this last couple weeks seems like she's going down hill way to fast.. I just got the book
          jag
          • selturk
            • Dec 2008
            • 1197
            do you have spark? if no.. check crankshaft position sensor. Also double check your relays and fuel filter.
              What a novel idea. The car wasn't running right so you stick 19lb injectors in to make it run even worse. Go back to the OE injectors and find/fix the engine's basic problems. Running the fuel system tests and a smoke test of the intake should be the first steps.
              • rooster
                • Jan 2009
                • 80
                No I didn't throw in the 19lb injectors to fix the issue I had a clean set layin around figured might aswell swap em in not like its gunna hurt it more than what it already is. Gunna wait for a budd to come over so I can check for spark
                jag
                  I didn't say that the injectors were an attempt to fix the problem. My point was that unless the engine was already running perfectly, mega-oversized injectors are just going to make the problems worse.
                  The fuel pump dropping out tends to point to:
                  No power to the DME (bad main relay, bad fusible link, or a wiring fault)
                  Bad CPS
                  Bad DME
                  Now lets hope that the overheat didn't kill the head or head gasket.
                  • rooster
                    • Jan 2009
                    • 80
                    So I checked for spark & I'm not getting any
                    jag
                    • Kershaw
                      • 11822
                      how did you check for spark?
                      my favorite method is pull a sparkplug, hold it, and have a friend crank the engine.
                      AWD > RWD
                        No spark could mean:
                        No power to the coil or a fault in the wiring between the DME & coil
                        No timing data to the DME
                        No power to the DME,
                        Bad DME
                        A bad coil is a possibility, but the other items have a higher probability.
                        • rooster
                          • Jan 2009
                          • 80
                          Update.. damn reference sensor
                          jag
                          • scabzzzz
                            Estado de mierda de encargo
                            • 6871
                            meow
