Does an air hammer work most of the time to remove bj's?
    I've always rigged up something and used my dad's enerpac 50 ton shop press. Sometimes tho it gets a little hairy. I saw online someone walking out a ball joint from an accord with a heavy duty air hammer. This works?
    Ma che cazzo state dicendo? :|
    It can, but a BMW ball joint press does the job with much less drama.
      So I should just stick to the floor press.
        That or spring for the tool you really should have for this job.
          You mean doing it by a hand press? Fuck that. Im not using a hand crank press.
            Having just spent several hours this weekend trying and failing to separate a VERY subborn balljoint using this tool:
            I can say that heat, penetrant and a press tool aren't always enough. When I need to actually install my coilovers I will be doing it with an airhammer. My balljoint boot be damned..
            '89 Alpine S52 with goodies
              That tool is a wimp compared to the BMW special tool for ball joints, I've yet to encounter a case where the BMW tool won't remove a ball joint.
                Damn you REALLY love your BMW ball joint tool.
                  Just a tip, if you wack the side of the hole wear the ball joint goes into with a hammer, it will generally break loose a stuck ball joint. Basically the metal deforms slightly, then rebound back, so it breaks the surface to surface contact.
                    Yea I do that all the time. it works like magic.
                      never had my air hammer NOT remove a stuck ball joint, tie rod end, control arm bushing....... get a good one (mine is snap-on) and dont worry about it.
                      I saved 15% on my Bimmer parts by switching to ...
                        Yea Im thinking the super duty snap on one.
                          jlevie what tool are you talking about??
                          1991 325iC - Mauritsblau sumthin metallic blue. DEAD
                          1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
                          1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
                          1991 325iC - Calypsorot Metallic
                          1994 540i - Granitsilber
                          Originally posted by scabzzzz
                          I've had blunts cock in my mouth, but I'm not gay.
                            assuming he means this: http://www.etoolcart.com/bmwballjoin...olbmw3028.aspx
                            which is used to press the ball joints out of the actual control arm. from what i can tell, OP is trying to get the ball joint out of the steering knuckle on the strut.
                            Moral of this story?
                              that works great, except for when it doesn't.
                              OP, just get a standard ball joint remover and be done with it.
