Does an air hammer work most of the time to remove bj's?
  • b*saint
    • 3794
    Originally posted by accident
    assuming he means this: http://www.etoolcart.com/bmwballjoin...olbmw3028.aspx
    which is used to press the ball joints out of the actual control arm. from what i can tell, OP is trying to get the ball joint out of the steering knuckle on the strut.
    Correct. And I dont have an air hammer but have other uses for it beside removing ball joints.
    Ma che cazzo state dicendo? :|
    • Axxe
      • Aug 2004
      • 3355
      Two hammer method, with a 4lb and a ball peen.
      Keep it slideways!!
      • b*saint
        • 3794
        So I did the job today. The bj came out like butter with an air hammer.
        • THE FEZMAN
          • Jun 2010
          • 89
          i just did the lower control arms on my 2001 330ci, i ended up having to use my air hammer the two hammer method a nice soaking of PB blaster and some heat to break the drivers side lowers loose. but the passenger side just popped with a quick whack with the air hammer and the pickle fork. i didn't care about the boot because i was changing the entire assembly.
          • b*saint
            • 3794
            Wait you mean splitting a ball joint or removing it from the control arm?
