lifting M42
  • noneone2
    • 26
    lifting M42
    Getting ready to do a front suspension refresh and replace the subframe (had tabs reinforced). Going to use a support bar but want to know if a little assist with a floor jack and 2x4 across the lower oil pan to distribute the load would be safe. The front of the car is on jack stands at the proper lift points. Just might need a little more clearance to clear the steering rack while the subframes are swapped.
    Thanks
    • 34847
    should be fine.
