Coverting R12 to R134, who's happy?
  • 91 318is
    • 1175
    So I need to service my A/C in the E30. I was considering changing it over to R134 just to freshen it up. I have access to R12, but it's easier for me just to buy R134 cans at the store.
    So my question is, who's converted their cars and is happy? I've read that a few people felt the R12 worked out better because of the way the system's designed? I plan on changing the drier, expansion valve and of course the adapters.
    Should I just service it with R12 and ride on?
    Comment?
    Sold.......again.
  • ak-
    • 12422
    I have R134. R12 blows very noticeably colder.
    /myexperience.
    1991 325iS turbo
    • Eric Giles
      • 1068
      If you have r12, stick with it.
      Eric Giles
      '20 M2 CS
      '04 M3
      '11 X5 35D
      '87 325is
      '91 325i Sport
      There are few things more expensive than a cheap BMW...
      • 91 318is
        • 1175
        Yeah I can get the R12, it would be kind of a hassle I think, but I can definitely get it.
        Just figured for the long run, R134 would be a better choice.
        Sold.......again.
        • slo325i
          • 417
          I have freeze-12 in mine and I love it. It gets COLD even in the hot Atlanta weather
          '89 325i - Totaled... good bye my love...
          '87 327i budget stroker - SOLD!!!
          '92 240sx - ca18det powered drift toy - SOLD!!!
          '89 325i - coupe - NEW daily
          '96 Audi A6 Quattro- Grocery getter/baby hauler
          '99 Busa - weekend wheelie monster
            The problem with R134 in these cars is that the condenser and evaporator aren't large enough for effective cooling. The system will work, it just won't cool nearly as well with R134 as with R12. I've seen a couple of conversions using R12 replacements (e.g. Freeze12 or similar) that worked much better than R134. That said if your system isn't leaky, it would make sense to retain the R12 until the system needs works and the R12 has to be dumped..
            • nrubenstein
              • 3148
              With the aid fan rigged to high, R134a works fairly well in my car.
              Here's the key: you MUST fill by weight. This means that you need a postal scale, and preferably a 30lbs. cylinder. Apparently, R12 works well a half pound to either side of optimal. R134a works well about 1.5 ounces to the side, so you have to be VERY precise.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • KenC
                King of Kegstands
                • 14396
                I'd do whatever you can to get the R-12. You're only recharging it once every 5+ years, so the "convenience" of the r134a availability is really moot.
                Originally posted by Gruelius
                • evil_twin
                  • Nov 2007
                  • 2965
                  Im looking for Freeze12 and I can't find it anywhere. I would love to put Freeze12 in my system, but R134 is just so much easier to find.
                  Paypal: vdang5@gmail.com
                  Delta Auto Care
                  2875-C Towerview Road
                  Herndon, VA
                  703.435.1375
                  My Feedback Thread: Evil_Twin
                  • Tbolt
                    • Nov 2007
                    • 1165
                    http://www.amazon.com/gp/product/B00...2S39CF83A4YQT5
                    will this work with e30s?
                    would i need anything else?
                    Tbolt Division
                    All I'm saying dude is that bird law in this country...it's not governed by reason.
                    • hoveringuy
                      • Dec 2005
                      • 2752
                      +1.
                      I lived in Maryland and ran Duracool (same as Freeze12). Car blew cold air unless I was stuck in really miserable beltway traffic.
                      R134 didn't cut it. Condensor is just too small!
                      Stick with R12 if possible.
                      • 91 318is
                        • 1175
                        Hmmm, are there any R12 substitutes at local parts stores like advance auto or NAPA? Or do I need to order Freeze 12 online? I don't think I have any leaks because the A/C works, it's just not very cold.
                        Sold.......again.
                        • PorkandBeans
                          • Oct 2009
                          • 75
                          How did you do this? My low speed resistor is out and my car never gets hot enough to kick the aux fan on high speed. I want it on high at all times the A/C/ is on. Do I just remove the resistor entirely?
                          1985 325e dd
                          • nrubenstein
                            • 3148
                            Change the fuse to 30 amps and bypass the resistor. You can splice the low wire to the high, or you can jump a wire across. It's very easy, and it makes the ac work a LOT better.
                            • PorkandBeans
                              • Oct 2009
                              • 75
                              I was just about to do this, tracking down a new resistor is pointless. Thanks for the confirmation. Fuse 3, right?
                              1985 325e dd
