Fixed my Washer Fluid warning light
  • Aus E30
    • Jul 2009
    • 478
    So a couple of weeks ago I got my first check light warning, washer fluid.
    Just being washer fluid I figured i'd just live with it.
    It started to bug me (I was proud of my warning free car)
    So started poking around seeing if there was dirt in it or w/e.
    Turns out that somehow the sensor had flipped itself 180 degrees, so instead of the float touching the sensor when empty (turning on the light) it was upside down, so the float was floating up into the sensor and activating the warning light.
    Easiest fix ever!
    Your signature picture has been removed. Refer to the Signature and Avatar Guidelines in The Rules.
    I <3 dead naked girls.
  • theox69
    • May 2008
    • 1732
    I might have to try that with mine...
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
    • TrackjunkiE30
      • Sep 2009
      • 151
      Mine did the same thing... but I thought it was a bad sensor, so I bought a new one. When I went to put it in, that is when I realized that it had flipped. Occam's razor gets me everytime.
      John
      2013 NASA-SE TTE Champion
      Tracks driven: AMP, Barber, CMP, CMS (Lowe's), Daytona, NCCAR, Road Atlanta, Rockingham, RRR, Sebring, Texas World Speedway, VIR (Full, Grand, South, North, & Patriot), Watkins Glen.
      • sector6
        • 909
        Thanks, good to know! I need to check mine now...
        • Boris3
          • Apr 2007
          • 444
          Mine had done the same last year, rotated enough so the float and contact were not closing and the light was on. Spun it around and it's been fine since. Question is what causes them to turn?
          1990 325: track/racecar
          2003 330xi; project car
          2004 330i zhp: civilized car
          • ak-
            • 12422
            speedbumps
            1991 325iS turbo
