I have a problem with locking the drivers side door lock.
I am unable to lock it at all, not with a key and not from the trunk. When i try to use the key, the lock barely moves, if i try to push down the door lock it does not budge.
If i lock from the trunk or passanger side, the locks close and then open immediatly. after 7 tries or so the the doors stay locked, passanger side stays locked and the trunk. But the drivers side door is still open.
What could cause this problem? actuator or something mechanical in the mechanism?
Thanks
Thanks
