Ok so I installed a new CSB yesterday on my car, the old one was destroyed. The previous owner had currently installed the guibo, tranny mounts. I check the u joints whilt putting in the CSB and tthey were good. I drove about 50 miles or less today and the brand new CSB failed. Any ideas on the source of the problem??
Unknown drive shaft problem
A failure of the CSB is almost always the result of binding u-joints in the drive shaft. Replacing just the CSB may gain temporary relief, but the news CSB will have a short life. The only long term fix is to replace both the CSB and drive shaft.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Does your car vibrate under power? you can usually tell a bad u-joint from the drivers seat.
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
yeah, it's new DS time...seriously!
On both my e30's I've replaced the DS's. I totally got rid of any vibrations caused by bad joints (usually occurs to the rear joint first).Comment
