LSD question
  • BMWerke
    • 893
    LSD question
    how do I take the lsd out of a 1986 325e. Do i need some sorta allen wrench for the axles? i need to have it out ASAP. and how do i get to the drive shaft, i dont have jack stands? PITA!!
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • Wh33lhop
    • 11705
    Get jack stands. And yes, you will need allen key sockets for the half shafts.
    paint sucks
    • BMWerke
      • 893
      i have allen keys but not big ass ones lol
      • Wh33lhop
        • 11705
        Well, are you really that adverse to buying tools? You need jack stands, and an allen sockets do come in handy every so often.
        paint sucks
        • BMWerke
          • 893
          i just dont have large sockets, my friend is lettin me borrow his jack stands tho
          • 4bangerfury
            • Aug 2009
            • 332
            make sure you don't accidentally pull apart the driveshaft.
            • b*saint
              • 3794
              E30's have allen keys? Or is it torx sockets?
              Ma che cazzo state dicendo? :|
              • Kershaw
                • 11822
                torx is a star pattern. allen is a smooth 6 sided hexagon.
                the half shafts are allen.
                AWD > RWD
                • Danny
                  • 14216
                  Allen for the axles.
                  • b*saint
                    • 3794
                    I know what the difference is between a torx and hex lol. But they must've changed it when they went to E36. My ti's both have torx sockets and I've never removed the axles on my e30.
                    • Wh33lhop
                      • 11705
                      It's an allen key, for sure.
                      Since you aren't dropping the subframe, I had to use a 19mm wrench and an epic cheater bar for the upper bolts (socket wouldn't fit). PB Blaster the shit out of those bolts as they were the hardest part of the swap for me, hopefully they are easier for you. I had to go to the hardware store twice to get longer and longer sections of pipe to use on the wrench.
                      paint sucks
                      • b*saint
                        • 3794
                        Know what I did? Forget a cheater bar. I took a grade 8 nut and bolt that a 19mm wrench fits onto and used the nut/bolt assembly as a coupling so I could use my 1/2" breaker bar with a 19mm socket. So it goes the 19mm wrench end on the case, nut into the other end, breaker bar (in this case I used my long 1/2" ratchet) and socket on the bolt side of the nut/bolt coupling. This way I can get a different angle if I need too AND its balls long.
                        • Wh33lhop
                          • 11705
                          Haha, I guess you could do that, duct tape it up maybe so it doesn't fall apart immediately.
                          paint sucks
                          • b*saint
                            • 3794
                            I just used my left hand and pulled with my right :|
                            • Kershaw
                              • 11822
                              or just use an impact wrench. i either used a 240ft/lb impact or a 18" breaker bar. getting the bolt off isnt that hard. getting the bushing down, out of the car, now thats a PITA.
                              AWD > RWD
