Question about the MEtric Blue headBolts
  • jcsomerset
    • Jan 2005
    • 17
    About to order the Metric blue head bolts -
    Can they be used more than once>?
    I've discovered some seepages between the cooling and oil passageways - Not sure if it's an intermittant thing or if I've got a blown gasket that's less than a year old - :evil:
    I'm going to try replacing/tightening the head bolts down to fix the gasket issue - but if they can only be used one time - I'm more likely to just replace the head gasket altogether; to make sure i'll fix the problem.
    I'm hoping one of the "stretch bolts" hasn't snapped off.. cause that'll suck.
    TIA guys!
    1987 m6 and 1989 325i
  • Beej '86 325es
    • 2639
    No, the head bolts are not reuseable. But they're only $24 from Bav. Auto.
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • jcsomerset
      • Jan 2005
      • 17
      I'm talking about the metric blue head bolts - these are a different brand found here - http://www.mcmaster.com/
      Material
      Class 12.9 Blue-Coated Alloy Steel
      Head Style
      Standard
      Drive Style
      Hex Socket
      System of Measurement
      Metric
      Thread Size
      M10
      Length
      150 mm
      Hex Key Size
      8 mm
      Thread Style
      Standard Right Handed
      Thread Length
      Partially Threaded
      They are not "stretch bolts" which is what the stock bolts are - you can't overtorque the stock bolts - they are likely to snap - which is why I'm going to replace them with these - I would rather install and over torque them to hopefully fix the leakage - as i don't have any nasty white smoke - but there's a "slight" film across the top of the coolant. Otherwise - with the losing coolant (cracked radiator overflow nozzle) issue excepted - the car runs fine - idles like a top and runs like a scalded dog.
      A lot of the FI guys use the metric blues -
      but if the Metric Blue's will not withstand 2 torquings - then I'll just get a new head gasket and rip the car apart in a weekend or 2 to replace it - which will really pi$$ me off. - I don't have time to schedule a full day to do it - but will if the metric blues won't withstand 2 torquings..
      I suppose I could just get 6 boxes of metric blues and be done with it either way.. but then I'd have an extra set if the first replacement fixes the problem..
      • draculia
        • Oct 2004
        • 36
        they're not stretchbolts, you can reuse them
        • Madhatter
          • Oct 2004
          • 966
          Standard bmw items are torque to yield (thats what the stretch bolts are).
          Dont be affraid of the high torque rating of the metric blues either, some owners have been shitting themselves because the torque is a fair bit higher than the standard bolts.
          Just a little project im working on
          - http://www.lse30.com -
          • jcsomerset
            • Jan 2005
            • 17
            Thanks - I think it was you that turned me onto them in a previous post -
            I'll get them here shortly - replace them one at the time like the book says - and torque them down to probably 70-80 lb's; it that doesnt' fix my issue - then it's head gasket time and I'll have to schedule at least a day for dissassembly/reassembly.... and as stated above -that'll make me cranky.
            • Madhatter
              • Oct 2004
              • 966
              might have been :oops:
              im using them for every engine now, kicks the arse out of the tty bolts bmw use, dont have to worry about one snapping and trashing my cam and wrecking my head 8)
              • draculia
                • Oct 2004
                • 36
                [quote="Madhatter"]^^^
                quote]
                if that was refered to me, i wasn't talking about the oe bolts
                • Madhatter
                  • Oct 2004
                  • 966
                  no, the ^^^ was me saying, the post above is right.
                  • kowalski
                    • Jan 2005
                    • 1791
                    24$ american? holy crap i can get them for 10$ can. localy with the hex style heads.
                    • draculia
                      • Oct 2004
                      • 36
                      the hex style heads are what everyone says to stay away from. boltheads flying off and whatnot. late style female torx is what you want
                      • ptownTSI
                        • Jun 2005
                        • 1265
                        i know lots of guys who have used internal hex bolts, never a problem.
                        • digger
                          • Nov 2005
                          • 6144
                          Whats special about the metric blue bolts?
                          Are they just like any Metric 12.9 Socket head Capscrews (say like brands such as UNBRAKO, YFS etc? What is the recommended tightening torque and tightening procedure?
                          What grade are the replacement torx ones plus the original hex head OEM ones. Are both the torx and OEM hex head ones torque to yield or only the torx ones?
                          Cheers
                          • mcgrath
                            • May 2004
                            • 445
                            both torx and hex bolts for the m20 are torque to yeild. As far as brand I have no idea if there is a difference. I just installed my 731 head on my eta block and I used the Metric Blues with the copper gasket spray and using the procedures written at e30tech. I have no leaks of any kind and had no problems torquing them down.
                            go to e30tech.com and go to the turbo section. There is a sticky thread there with all you need to know. Cost me $36.something shipped to my door.
                            Steven
                            • SoopaGhetto
                              • 573
                              would the metric blues work with the m10 block?
