Sandblasting A Flywheel?
  • ZiMMie
    • Jun 2004
    • 968
    I have a flywheel which was machines couple months ago. since it was in the garrage surface rust has been growin on it. i was jst wondering if its advisable to sandblast it and jst coat it with some vaseline? wen i get ready to install it ill remove the vaseline from it. But i have never heard of flywheels been sandblast? any ideas? shoud i do it or get it machined again?
    www.stancefactory.com
  • Jordan
    • 12916
    sandblasting would ruin the friction surface.
    Dont worry about the surface rust, it wont hurt anything.
    https://mtechniqueabs.com/
    • ZiMMie
      • Jun 2004
      • 968
      u wont worry about this?? i jst got Sash powerclutch and i would be pissed if it fucks its up. :oops:
      • Dave
        E30 RAT
        • 11675
        I think I'm with Jordan on this one. the surface rust won;t hurt anything.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • ZiMMie
          • Jun 2004
          • 968
          Ok if u guys say so 8)
          • Jordan
            • 12916
            Yeah, honestly it will be fine. If you want get some of that 3M scotchbrite scuff pad stuff and scuff the rust off. It will do a great job.
            • Tangent
              • Mar 2004
              • 476
              A clutch works on the same priciples as your brakes do and the average brake rotor will rust in a matter of hours under the right conditions. (I've seen rust on the brake rotors of cars at my works parkign lot that I knew where driven just a matter of hours before) That little bit of surface rust will get knocked of within the first .005 second of clutch slip. The only reason clutches come packed in rust preventative is so they look good when they're sold...
              • Dirtsquirt
                • Nov 2004
                • 686
                I don't agree that sandblasting the surface is super harmful to the clutch.
                It's a engine building "trick" when it comes to ATV and dirtbikes. A roughed up surface on the slide plates give the friction plates something to grab to and help in enagement, at least for the first few engagements. The surface will wear smooth again but it is fun while it lasts.
                -Dan
                • DaN
                  • 1265
                  -Dan
                  I (Dan) am going to back up Dan on this one. I would sandblast it, or at least clean it before installation.
