Trunk question
    Trunk question
    I was removing the tar out of my trunk this morning and came across three things. One is a rather thick wire with a large connector. The next is a small wire that appears to be speaker wire. It has a fuse connector on the end. The other is an electrical box ahead of the antenna. Is it the amp? Could the others be for a phone or cd changer?
    Could be anything, post pics.
      Does your car have premium sound? If so, look for "Blaupunkt" somewhere on the box. I *think* that's the brand.
        The box is tucked behind the bracket for the trunk lid. I'll see if I can get pictures
          It's most likely the amp.
            ya thats the brand of the amp. and thats exactly where its located.
              It was indeed the amp. Next questions is whether or not there is anything in the wiring loom to the amp that cannot be removed. I have started to take it all out, but I wanted to check to see if I am going to disconnect anything I need. There were a couple of gray and brown wires that cut across under the driver’s seat. Where do these go?
              Another question. I have removed the cruise control stalk and the parts in the engine bay. The computer is above the glove box correct? What should I look for?
              Last question. The tar below the back seat. Any reason not to remove?
              Thanks
