Random beeping
  • agent orange
    • Mar 2005
    • 32
    Random beeping
    Wasn't sure where to post this, but I've been noticing pretty much any time I take a corner really hard, it beeps at me. it's a 91 318i, M42 engine.
    is this an actual problem with the engine, or some kind of traction control?
    any info is appreciated.
    Thanks.
  • Sean
    • 5793
    Not traction control. Does the check panel light up? (does your car HAVE a check panel?)
    Does your OBC/temp display/clock/etc blink?
    Is it a beep, or a GONG sound, like when the doors open?
    - Sean Hayes
    • hamann318is
      • 3382
      We don't have check panels.
      The BMW 318 is back. With a vengeance.
      • Sean
        • 5793
        Bah, I couldn't remember if some came with them or not, wasn't sure.
        Thanks for the clerification.
        In that case - what does the beep sound like? ;)
        - Sean Hayes
        • James Crivellone
          Head Janitor
          • 6305
          Is MEMO on your digital clock turned on?
          • e30evolution
            West Werks
            • 1888
            you might have an intermitant short on your ambient temp sensor.... when it is diconnected the OBC will read -30 degrees celcius or 0 farenheit
            when the temp gets cold the temp is automatically displayed on the OBC with a ding to notify driver of the cold conditions......
            watch out for ICE
            (post 1000)
            http://www.westwerksauto.com
            • Anthrsckmnd
              • Aug 2004
              • 241
              This is really random, but if it's the door gong beeping sound, I had the same problem, and I figured out that if my seat is in the fully down position (Pushing down on the front seat adjuster handle) the car beeps at me while turning or braking hard. Don't know if it's pinching a wire or what. Never figured out why, just re-adjusted my seat up a little, and it doesn't do it anymore. (btw I have a 318is w/ sport seats, so might not apply to you)
              • e9nine
                • 1890
                Have u tried wiggling your door switch? That would cause the chime to go off in turns. I think* the seatbelt does that too. Best way to test the door switch would be to have your interior light set to the door position, when it's at night see if the noise coincides with your light coming on.
                • e304lyfe
                  • 807
                  while fixing the problem is all good and well... why not just disconnect it? i find the beeps are pointless.
