what does this plug into?
  • call me jack
    • Jul 2010
    • 425
    so i got my 87 325e all put together (after buying it with pretty much no front end) and i keep stumbling across this plug.... i looks like it should plug into the radiator for a temp gauge but it's not long enough, and i already have that plugged in... it's right below the driver side head lights... any suggestions? the ac is on the other side of the car...
  • dkbmxer002
    • Nov 2007
    • 1389
    looks like the plug that goes into the radiator side on the passanger side.
    edit: i have the same thing on mine just free sitting haha. always wondered what it went to, but never cared enough to look.
    • call me jack
      • Jul 2010
      • 425
      i think the temp sensors are on different sides on the e and is (your sig indicates you have an is, or at least an i) and i know the coolant tanks and some other stuff are flip flopped between models... but yeah... weird little bugger, aint it?
      • dkbmxer002
        • Nov 2007
        • 1389
        haha yea... and yes i have a 318is.
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          Electric fan?
          • 87e30
            • Jul 2008
            • 5676
            I have one hanging on both drivers side and pass side of my car and I've been perplexed by it. Always felt ashamed I didn't know what it was for... maybe I'm not alone.
            I just hate everyone.
            No need for discretion.
            • Hairos E30
              • Mar 2008
              • 378
              I have this same plug just sitting there and never figured where it went. Does anybody know?
              • Wishno87
                • 6025
                AUX fan right?
                • SlapDash
                  • Jan 2009
                  • 675
                  Horns? Foglights?
                  I have one two-pronged plug hanging next to my fuse box and have no idea where that goes either.
                  Good luck.
                  www.slapdashracing.com
                  • Kershaw
                    • 11822
                    those look like foglights to me.
                    in the future, turn 1 thing on inside the car, and then use a multimeter to check the wire. you will eventually find it.
                    AWD > RWD
                    • AbsorbantNut
                      Non faccio funzionare questa merda
                      • Jun 2010
                      • 2491
                      fogs only have 2 prong connector
                      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                      • wodcutr
                        • Apr 2009
                        • 2193
                        It's for the auxillary fan. Is yours functioning?
                        The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
                        • 87e30
                          • Jul 2008
                          • 5676
                          Since it's for the aux fan is there a way to set up the electric fan to run off of it?
                          I have two three pronged neither connected to anything on my swap.
                          And I have two two prong, I'm fogless thanks to some PO so i now just use the fog light circuit for my fan switch.
