How do you depressureize the fuel system?
  • bmwannabe
    • 900
    Im putting in new fuel injector seals, anyone know how to go about depressureizing before i go blind with 93 octane?
  • rs4pro3
    • 5808
    Unplug the battery and let it set for a day or so. I've never had a problem with fuel squirting unless you just cranked the car a couple minutes earlier.
    85 325e 2.7 ITB'd stroker
      • 34839
      pull out the fuel pump relay, start the car, it'll die once the fuel pressure runs out.
      • bmwannabe
        • 900
        good call, thanx
        • randomtask37
          • 3154
          just for future reference, where is that relay?
          98 M3/4/5
          • DaN
            • 1265
            It should be under the black plastic cover on the drivers side in the engine compartment.
            It should be in the middle of two other relays, at least thats how mine is. Yours could be set up a little different.
            I would just start the car and pull it, if it dies right away its the wrong one, if it takes about 10 seconds for it to die, you found it.
            • chesster6969
              • 321
              I remove the fuse to the fuel pump instead. Then I turn on car and let it die. THere's still going to be some pressure left though so be careful.
