So I installed another used engine in the car. When i went to turn the key on, the engine did not turn over at all. But when I jumped from the starter, the engine ran. It has to be problem in between the started and the ignition switch. Should it be a problem with the started solenoid or ignition/starter relay? This situation is throwing me for a loop. What number is relay in the fuse box?
ignition problem
