My temp gauge was flickering and now it barely moves. Is the sending unit likely faulty and if so which of the two located around the thermostat housing is it.
Flickering temp gauge.
When you say "flickering", do you mean it jumps around quickly? If so, tighten the ground screw behind the gauge.I Timothy 2:1-2 -
ground screw loose or corrosion.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
