Wipers dont work
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    Wipers dont work
    Whats up with that. I go to test them out when its raining and nothing. Is there anything other than the motor that could be causing this?
    Thanks guys
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
  • mrsleeve
    • Mar 2005
    • 16389
    switch, Relay, fuse????
    Originally posted by Fusion
    William Pitt-
    • F34R
      sLaughter
      • 12376
      Buy a Bentley manuel yet? Best bucks I have spent to date. Amazon is best.
      Check the cheap and easy stuff first. 1+ on Mrsleeve
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • AbsorbantNut
        • Jun 2010
        • 2491
        switch is a no, but thats the answer I was looking for, the relay. Which relay is the wiper relay? Is it in that cluster of 3 off to the side of the fuze box?
        Nope, still rockin my haynes strong as ever:D
        Same question as aboe, wheres the wiper relay
        • F34R
          sLaughter
          • 12376
          In the fuse box, big long one closer to the engine. You need to buy a bentley my friend!
          Current cars:
          ~ '87 535
          ~ '06 X5 4.8is
          • AbsorbantNut
            • Jun 2010
            • 2491
            So it's part of the main relay? And I know, but between the haynes and you guys, why add a 3rd wheel?
            • F34R
              sLaughter
              • 12376
              I threw mine out! haynes fucking sucks. Buy the Bentley and you won't have to ask questions like these. It is covered in detail and has pictures too :D
              Current cars:
              ~ '87 535
              ~ '06 X5 4.8is
              • AbsorbantNut
                • Jun 2010
                • 2491
                Ill consider it, after Im done with the suspension though.
                • F34R
                  sLaughter
                  • 12376
                  No, the "main" relays as you call them are as followed: Main, fuel pump, o2 sensor
                  Haynes sucks, and I am sure not all of us wants to look it up in our Bentley for you ;)
                  The wiper relay is in the FUSE box, not with the three relays. It will be double the size of a normal relay and black if I recall.
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • F34R
                    sLaughter
                    • 12376
                    Here is what is looks like:
                    It is #1
                    http://www.realoem.com/bmw/showparts...38&hg=61&fg=25
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • F34R
                      sLaughter
                      • 12376
                      Buy it, I could not put it down the first two weeks I had it. 32 bucks is not much for the nutty amount of info in it.
                      http://www.amazon.com/gp/offer-listi...condition=used
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        OK, ok I get it, I need a bently.
                        It is #1
                        Gotcha, thanks for the follow up
                        Ill get it when I get my paycheck, which is next week. Or maybe Silence/forced Firebird has a spare copy for less:o
                        • 619E30
                          • 1753
                          Mine does the same, sometimes it works and sometimes it doesn't. What's causing this, a short?
                          Originally posted by audiquattrot
                          bimmers b4 b*tches....remember that.
                          1990 Alpinweiss 325i - secret 500whp build
                          2000 Audi S4 B5 Laser Red
                          1990 Nissan 240sx - Drift Missile
                          2006 CBR600RR
                          • AbsorbantNut
                            • Jun 2010
                            • 2491
                            No, they dont work at all, sorry if I was confusing, but they dont work period.
                            Im gonna try and swap relays with the vert tomorrow
                            • F34R
                              sLaughter
                              • 12376
                              Could be the wiper switch on the steering column or the relay. Just start from over looking wires and then relays and switches.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
