Wipers dont work
  • F34R
    sLaughter
    • 12385
    Originally posted by AbsorbantNut
    OK, ok I get it, I need a bently.
    Gotcha, thanks for the follow up
    Ill get it when I get my paycheck, which is next week. Or maybe Silence/forced Firebird has a spare copy for less:o
    Now your seeing the light ;)
    You are most welcome, and maybe he does!!! I know the manuel has saved me HOURS of time narrowing down issues.
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • 36brua
      • 689
      Here .. even easier down load the Bentley Manual to your computer
      My CA legal M60 swap
      The happening in our garage
        • 34829
        Originally posted by 619E30
        Mine does the same, sometimes it works and sometimes it doesn't. What's causing this, a short?
        the motor is probably bad.
        • bimmer_E30
          • 5001
          i replaced mine on my old eta, wasn't really fun at all.
          but O.P check the Fuse first. could be that simple.
          Originally posted by e30e
          • Quadrajet
            • Jul 2008
            • 1278
            It could be as simple as the connector at the motor got disconnected. My 318iS was like that when I purchased it.
            I was hoping this thread would be about an intermittent problem like mine.
              • 34829
              I thought it was surprisingly easy. the blower motor was way friggn' harder. wiper motor was an hour taking it easy.
              • KillaCams
                • Mar 2008
                • 998
                I had this problem on 2 of the E30's i had, both times it was the wiper switch. Try playing with the switch moving it in different directions and see if the wipers kick on, i used to wiggle mine back and forth and up and down to get the wipers to work until i was able to get a good switch to replace it with.
                • AbsorbantNut
                  Non faccio funzionare questa merda
                  • Jun 2010
                  • 2491
                  Well sadly, its a no go:(
                  I wiggled the switch, swapped the relay, and the fuse. I banged on it a little to try to get it unstuck, but to no avail. Then I put it on the slow setting and tried moving it by hand at the same time. I could hear it trying, but its dead
                  Well, guess I'd have to go through some more pain sooner or later. Should I go for that DTM look with a mono wiper? I kinda like it, but I wont center it in the center, Ill keep it low. Or should I stick with the double?
                  '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                    • 34829
                    removing the linkage is an ungodly PITA. try replacing the motor first.
                    • bimmer_E30
                      • 5001
                      Did it work before? mine was actually making a burning smell and died slowly then finally gave up :/
