Checking Timing Belt ???
  • nicky51
    • Jan 2010
    • 158
    Is there any way to check the condition of your timing belt to check for wear.. Oh, its an m20b25.. Thanks..
  • ForcedFirebird
    • Feb 2007
    • 8300
    Well if you are questioning it, replace it ;)
    john@m20guru.com
    Links:
    • nicky51
      • Jan 2010
      • 158
      Reply
      Yes i know.. but i bought it from someone that said it was changed so i would just like to make sure with my own eyes ....
      • ForcedFirebird
        • Feb 2007
        • 8300
        In that case, take the timing cover off and inspect it. Usually if the belt was replaced, there will be a sticker somewhere saying the date/mileage. Most timing belts come with a sticker as a reminder...
        john@m20guru.com
        Links:
        • accident
          • 7303
          dont take the risk, just change it.
          Moral of this story?
          • nicky51
            • Jan 2010
            • 158
            reply
            Ok guys.Thanks for the input...
            • Atreus
              • 1846
              visual inspection may help, i mean im sure you know what a new(er) belt looks like. but you seem like a strapping young man, you don't wanna turn a timing belt job into a head swap do you? :D
              1991 325iC - Mauritsblau sumthin metallic blue. DEAD
              1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
              1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
              1991 325iC - Calypsorot Metallic
              1994 540i - Granitsilber
              Originally posted by scabzzzz
              I've had blunts cock in my mouth, but I'm not gay.
              • llll1l1ll
                • 782
                Removing the timing cover is half the job in itself. If you are unsure, just check.
                After you replace it, though, you can check the condition. Just look on the underside for cracks. Deep, perpendicular cracks are bad. Small little slits are generally okay. However, a timing belt is pretty sturdy compared to a v-belt.
                Me: "I can't wait to redline my car!"
                Mark: "Didn't you just break a rocker arm?"
                Me: "Yeah, I don't think I've learned my lesson."
                Mark: "You never will."
                • Need4Speed1299
                  • Oct 2007
                  • 119
                  Seriously everyone? Its very easy to check.
                  Heres what you need to do.
                  Lift the black plastic cover, and feel it. It should have a little bit of slack, I believe no more than a 1/8in? Make sure you put the cover back into place. You really dont have to take it off, you can noodle your fingers underneath it.
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    Yeah, but if the tensioner was tightened properly, and isn't at the end of the slot, then there shouldn't be any slack. My concern would be the age of the belt, as I have seen a few belts go on customers' cars, one appeared to be in excellent condition, yet about 6 or 7 cogs ripped off it.
                    john@m20guru.com
                    Links:
                    • lole30
                      • Jun 2010
                      • 29
                      timing belts aren't easily inspected. It may seem to have proper tension and look good while tensioned but once you take it off a whole different story.
                      P.O. of my vehicle told me that the t-belt was replaced 20k miles ago. Considering a t-belt and water pump job costs about $70 in parts I was like minuswhale do it for peace of mind. Took the covers off belt looked okay good tension. take the belt off and flexed it and could see cracks in the belt and peeled off a good 5 inch piece of the belt of the smooth side of it.
                      • qu4ttro
                        • Jul 2010
                        • 28
                        Agreed... Its the cheapest insurance you can buy, and youll bond with your car by spending some quality time...
