Help with top 2 tranny bolts on 325IS getrag 260
  • mike87
    • 300
    hello all, removing my first tranny ever with a buddy and got stuck on the top two bolts. i can't think of how to access them, yet people have removed the tranny without pulling the engine/whole assembly.
    i'm having trouble with the top starter bolt and the top-most torx bolt. we dropped the rear transmission bracket and the assembly is resting on the crossmember. there are a lot of wires blocking the view in the engine bay.. should i remove the intake manifold and rubberhoses/wires?
    at my disposal, i have a 3/8 u-joint, 24" 3/8 extension, two 6" 3/8 extensions, torx sockets, 3/8 to 1/2 converter, 1/2 breaker bar, 3/8 ratchet, and metric spanners/metric sockets
    i think i have to hug the transmission to get the top-most torx bolt off, but what i'm really looking for is information on how to do the top starter motor bolt :(
    any help would be appreciated. also, apologies if this was already posted somewhere on the forum, i already did a diligent search but couldn't find a lot of info. if someone could point me in the right direction, that'd also be great.
    thanks!
  • AndrewBird
    The Mad Scientist
    • 11898
    You have to get them from the backside (not the engine bay) and it is a major pain in the ass. Wobble extensions help. Best of luck!
      • 37829
      With the right tools, it's really easy. If you don't have the right universal joints, extensions, etc go buy them.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • SpecM
        • Oct 2005
        • 4531
        I always can get the starter bolts from the engine bay side. Use a socket + extention on the 17mm nut running next to the block and a screwdriver wegded against the bellhousing to stop the bolt head from turning.
        1989 cirrisblau-metallic 325i
        • Need4Speed1299
          • Oct 2007
          • 119
          You need like 3-4 feet of extension on 3/8 drive with one of these-
          One of those you circled is a starter bolt. You need someone to hold a wrench on the nut on the other side of the bolt.
          • DRTSRFR
            • May 2008
            • 1836
            This is my contraption...
            Suspension tips here...
            http://www.r3vlimited.com/board/album.php?albumid=757
            • b*saint
              • 3794
              Snappy sells Blue Point locking extention set. Get the long set.
              Ma che cazzo state dicendo? :|
              • blocke
                • 1305
                It will also help if you lower the front subframe a bit, or jack up the font of the engine to tilt it down in back and give you more clearance. Depends if you are doing this on a lift, or on the ground, and if you have access to a tranny jack.
                Parts Wanted
                The Never-ending Resto Mod
                • mike87
                  • 300
                  thanks for everyone's help in this thread:
                  i finally managed to get my tranny off. the top-most bolt was already loose :( so i just used my fingers and took it off. the top starter motor bolt was a B*TCH, but my tools and i got it off within a couple of hours.
                  new questions here:
                  • hoveringuy
                    • Dec 2005
                    • 2715
                    Make sure your extensions are quality stuff. I've broken 3 so far, still haven't gotten that top bolt off!
                    The Torx is starting to round-off and if I can't get it tomorrow I'll need to lower the whole engine for that one damn bolt...
                    • riceh8r
                      • Dec 2010
                      • 133
                      you can use an etorx wrench (craftsman combo) from the top to loosen the top two bolts, then use the extensions to complete. i broke several swivals, then got the impact wobble, but the wrench from the top was the lifesaver. of course my intake, head and starter were already off.
