Strength of E30 gearboxes
  • Drew325is
    • Oct 2004
    • 520
    Hi all. A poster on another forum has said that E30 gearboxes, the 260 Getrag in particular, are really weak and fail easily. This is the first time in numerous years of E30 ownership and keeping up to date via forums that I have heard someone say this. What are the experiences of people here?
    I'm mostly concerned because I was planning on using the standard box from my '88 325is for my M52 conversion.
    Cheers!
    • 34839
    I've never heard this either.. think about how many E30s with getrag 260s have over 200,000 miles on them.
    • Axxe
      • Aug 2004
      • 3355
      My getrag 260 has 410,000 kms on it in the original car, and now another 15,000 in my car. That's 425,000 kms on it an it's shifting smooth and I don't have a single problem with it, except for the whine that plagues every M20 powered car I test drove.
      Keep it slideways!!
      • 808BMW
        • 2910
        I thought our Getrag 260 is stronger and better than newer e36 gearboxes?
        Sounds like you got a dose of bad info from that guy, everything I've seen points out our gearboxes as a strong point... You'll break other parts numerous times before your tranny goes out.
        • Jordan
          • 12913
          It is.
          The 260 is a very stout little box of gears. I don't know of too many people that have managed to break them. I broke mine on the second day driving my e30 because I shift too damn fast. Sheered off 2 hardended steel shifter forks inside the tranny. He he he.
          In all seriousness though, plenty of people run a 260 mated to 450+ turbo'ed hp with no apparent issues.
          https://mtechniqueabs.com/
          • BahnE30
            • 1050
            tough as nails getrag 260's are.
            • Jand3rson
              • 37587
              Yoda has spoken. The Jedi indeed ARE all knowing.
              I agree, Getrag 260's are the shit. I don't shift hard at all, most of the time very smoothly and easily. But when I'm out to have a little fun, and I'm slamming the gears hard, I get no back-talk from the tranny.
              • hamann318is
                • 3382
                The 240 isn't that bad either. I've shifted all kinds of ways and nothing has really bothered the transmission.
                The BMW 318 is back. With a vengeance.
                • BahnE30
                  • 1050
                  they like it rough, they also like they're redline MTL best stuff invented by man in a long time
                  • kowalski
                    • Jan 2005
                    • 1791
                    i agree those things are bullet proff, my friends matting one to a V8 due to space constrants in the custom car hes building it was the smallest one he could find that could handle the power.
                    • Drew325is
                      • Oct 2004
                      • 520
                      Well, I feel better!
                      • Stu Mc
                        • 4083
                        That's invalid because of the minimal torque load going through that tranny. I think anyone would have a tough time thrashing that 'box with a stock motor. ;)
                        Hartge and other companies put the Getrag 260 behind built 3.5L M30's in 3300 pound E28's. :idea:
                        • fabianyee
                          • 195
                          Would it be possible to swap the 260 into the 318is wihout changing the prop shaft?
                          BMWClub Malaysia
                          www.bmwclubmalaysia.com
                          • Stu Mc
                            • 4083
                            Fab, I am assuming you refer to what we call the drive-shaft. No, the 318 driveshaft is much longer, since the smaller trans is shorter.
                            • fabianyee
                              • 195
                              ok.. but we use the term propeller shaft to distiguish it from the 2 driveshafts... anyway, is the lenght of the casing the same for both Getrag 240 and getrag 260????
                              BMWClub Malaysia
