What floor jack do you use/recommend
  • eighteight325is
    • Apr 2006
    • 204
    I bought a 1.5 ton aluminum racing jack years ago when I had to lug it up or down a flight of stairs from an apartment to work on my cars. It works and will probably make for a nice secondary for putting under suspensions, cross-members, transmissions while working on them. Things I do not like about it:
    • Low lift height
    • Can only lift 1.5 tons
    • Despite low saddle height, cannot get under lowered cars w/out pre-jacking or stacking boards
    So now that I have a garage and another vehicle that is much heavier and requires more than 17.75 inches of lift height I'm in the market for a new floor jack. What do you use, what do you recommend R3V!
  • nrubenstein
    • 3148
    AC Hydraulics.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • browntown
      • Jun 2004
      • 3524
      ac hydraulics are the shiznit, but if you can't swing that, I bought an omega magic lift and love it:
      Found here
      Comparison of the two
      Video of above referenced jack in action:
      And the thread that has already hashed this out here:
      • eighteight325is
        • Apr 2006
        • 204
        Thanks for the info and link. I searched for "floor jack" and got about 87 thousand hits most in the do it yourself sections with the first sentence being "first jack up your car" :)
        • b*saint
          • 3794
          Dont buy Harbor Freight. I have one and it doesnt strike confidence in me.
          Ma che cazzo state dicendo? :|
          • stormspike
            • 401
            I got a sears one that came with stands, etc. Pretty nice. Dont get Harbor Freight. I like Harbor, but I dont trust their stuff on anthing that is holding up 2000 lbs over my head :)
            • george graves
              • 20003
              The "black magic" (or something) jack from walmart blows. I hate it.
              Originally posted by Matt-B
              • Jonny Cash
                • 1763
                I have that 2 ton aluminum low-pro Craftsmen jack. It lifts really fast and its really low and lightweight. But the first three i had were defective- the fourth one has lasted 3 years but I still dont trust it. I remember 10+ years ago they were solid as a rock, but not so much anymore.
                -Jay
                2014 NASA FL se30 champ #81
                2001 se46 3 year plan in progress
                • KenC
                  King of Kegstands
                  • 14396
                  Ive used the harbor freight one tons of times. For $60 you can't beat it.
                  Originally posted by Gruelius
                  • FredK
                    • 14763
                    The Omega/Blackhawk 29023 will just reach the front crossmember, but you don't have to drive on boards or do anything silly to get there (well, unless you have a slammed M42-powered car and the oil pan is 1" off the ground). You have to bottom it out against the front lip and push it back maybe half an inch and it'll saddle the front crossmember perfectly.
                    • leone30
                      • Jan 2009
                      • 25
                      I use 4 scissor jacks from RV. Bolted two 3/4 thick soft wood blocks on top of each to accomodate spot weld sheet metal flange.
                      works for me
                      • Boris3
                        • Apr 2007
                        • 444
                        I had bad luck with the 2 ton Sears jack as well. Nice while it worked but seals starting leaking badly after two years. Reviews on the Sears site mostly say do not buy. Should have read them first. I picked up the $60 Harbor Freight jack. OK for the e30 but doesn't have the height and weight capacity you're looking for.
                        1990 325: track/racecar
                        2003 330xi; project car
                        2004 330i zhp: civilized car
                        • Jand3rson
                          • 37587
                          I got mine at Costco a few years ago for $90, and it's the best jack I've ever owned. Pretty low profile, I still have to wind up one side of my car with the widowmaker to get it under the front, tho.
                          5 pumps to full-height (not full height in pic)
                            • 34844
                            Low profile ramps, Josh. Everyone laughed when somebody posted them like 5 years ago, but seriously they're perfect for basic work on a lowered car, and to get a jack under it. I use it to change my oil, no jack required. And on my wife's subaru, they're enough to make changing the oil comfortable.
                            the "widowmaker" I keep around for "just in case", but it's seriously scary. I've had it almost fall over on me twice. I'm thinking I'd rather toss it in the trash and put a bottle jack in the trunk or something.
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              ^I've tried in vain to find extra-low profile ramps for years. Where do you get them?
