block heater on m20
    block heater on m20
    Anyone use one? Was the install a PIA?
    I installed one, very easy, just remove the freeze plug and hammer in the heater element (a bit fiddly to get in but not hard), takes only a few min.
    its next to the oil filter
      What is this for exactly?
      www.CASTROMOTORSPORT.com
      Castro Motorsport
      12600 Sherman Way, Unit C
      North Hollywood, CA 91605
      818-765-3606
      Follow Castro's on Facebook:
      http://www.facebook.com/pages/Castro...02411516506828
      Follow Castro's on Instagram:
      http://instagram.com/castromotorsport#
        Very cold climates, it heats up the block to get it warmed up faster.
        It makes cold starts easier as well.
          heats up the coolant so its warm and nice when u start the car, very good for the engine when u dont crank it when it -32C outside :p
            your oil filter mounts differently than mine.
              You have an m42... your oil filter won't come close to getting in the way.
                I have both
                  In that case, you can rotate the oil filter 180 degrees, or just plug the block heater into another freeze plug hole.
                    What do you need a block heater for in texas?
                    '89 Alpine S52 with goodies
                      well the ones with power steering has an adapter on the oilfilter so the filter is 90 degrees in another direction. I don't have power steering on my car
                        all of my e30s had one, except the black one because it's orignally from the PNW.
                        *edit* my vert didn't have one, it's a cali car!
                        Originally posted by e30e
                          I am doing a oil heater that goes into the oil pan and will hopefully get the oil up to about 140 or so before I start the car.
                          Brian Jacobs
