Steering wheel locked in.. stuck on steering column
  • IminDiegoTriick
    • Oct 2009
    • 1564
    I have a quick release hub that I wrenched in to the steering column. The steering wheel lock is on it and now the wheel is locked in and i cant turn the key because its in that stuck position!! what can I do!?
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
  • jclar
    • 265
    Put the key in the ignition and with one hand wiggle it as far as you can to each side, or put alot of pressure on it on one side and turn the key when it releases. Don't break your key, the key itself needs no more pressure than normal. You'll feel silly when you get it, pretty simple.
    '86 325es M50
    • IminDiegoTriick
      • Oct 2009
      • 1564
      I tried what you said & it really is stuck! tried wiggling it as far to each side and the pressure one side.. It just wont rotate and turn! The lock is stuck on the hub
      I'm so gone ✗ ♥ O
      • IminDiegoTriick
        • Oct 2009
        • 1564
        This is what im talking about..
        neeeeed urgent help
        I'm so gone ✗ ♥ O
        • IminDiegoTriick
          • Oct 2009
          • 1564
          I overtightened the lock nut..
          I'm so gone ✗ ♥ O
          • IminDiegoTriick
            • Oct 2009
            • 1564
            OOOOOOOOOOOOOOOOOOOOHHHHHHHHH MYYYYYYYY GOD im an idiot
            I'm so gone ✗ ♥ O
            • Van Westervelt
              • 9365
              Originally posted by IminDiegoTriick
              im an idiot
              Before entering this thread, I could tell it was going to end up here. lol
              • IminDiegoTriick
                • Oct 2009
                • 1564
                Im not even gonna lie. What I did was soooooo stupid. im facepalming myself over & over.
                I need help :( I just got done fixing her electrical gremlin & got her to start & now this!! :(
                I'm so gone ✗ ♥ O
                • Dominic49
                  • Feb 2007
                  • 1373
                  take a dremel and cut the bitch
                  • scottinAZ
                    • Dec 2009
                    • 1312
                    +1, you have access to it, and will most likely do more damage trying to remove it any other way.
                    I saved 15% on my Bimmer parts by switching to ...
                    • IminDiegoTriick
                      • Oct 2009
                      • 1564
                      Is that really my only option?
                      I'm so gone ✗ ♥ O
                      • Dominic49
                        • Feb 2007
                        • 1373
                        is it a bad option?
                        you could also use an air chissel or a maltov cocktail.
                        • IminDiegoTriick
                          • Oct 2009
                          • 1564
                          is it a bad option?
                          lol its not a bad option.. i was just hoping it wasnt my only option! never used a dremel before but I got one. damn
                          I'm so gone ✗ ♥ O
                          • IminDiegoTriick
                            • Oct 2009
                            • 1564
                            What if I just change the tumbler.. curious as to if this can help lower the lock.. you know?
                            I'm so gone ✗ ♥ O
                            • scottinAZ
                              • Dec 2009
                              • 1312
                              if you can remove the tumbler assy, then you may be able to retract the lock pin. otherwise you are fucked and need to dremel the the lock off to release the wheel. just dont beat on it with a hammer, you will fuck things up worse that way, than just dremeling off the offending lock piece
