the catalytic converter blues...
  • 1985bmw325e
    • Mar 2004
    • 474
    well, it's time for a new catalytic converter. Didn't pass smog test and when i looked at the nox reading, numbers are really close to the max. So instead of buying an oem catalytic converter worth more than my car, what other options do i have? i'm looking for reliability and a durable aftermarket catalytic converter that won't crap out on me in 3 years. People use magnaflow catalytic converters.....will i still pass smog with that type of cat?
    feedback would be greatly appreciated since my registration date is coming up soon.
  • bmwsmurf
    • 509
    Re: the catalytic converter blues...
    How do you know it's the cat and not something else (i.e. when was the O2 sensor replaced, is the fuel regulator, any vacuum leaks, are the plugs old, etc).
    I did a quick search, most people say DEC or CATCO cats are the way to go. Not that expensive either!
    Visit the 3 series heritage site (work in progress):
    http://www.creativesmurf.com
    • joecoolinatl
      • Sep 2004
      • 121
      Catalytic Converter NOx Emissions
      Thousands of technicians have faced the challenge of bringing a particularly stubborn application into compliance for NOx emissions. High NOx readings are a clear sign of performance issues somewhere in the system. The question is, where?
      Among the potential causes of non-compliant NOx readings are:
      Misfire condition
      Malfunctioning or improperly adjusted EGR valve
      Failed oxygen sensor
      Leak in exhaust tubing upstream of converter
      Excessive carbon deposits in combustion chamber
      Improper spark advance
      Blocked coolant passage
      Overly lean air-fuel mixture
      Damaged cold air duct
      Corroded or damaged engine sensor electrical connections
      Please note that while a failed catalytic could contribute to high NOx readings, the failure in itself most likely would have been caused by some other upstream performance problem. In all cases, it is crucial to identify the root cause of the problem before blaming the poor converter. Just the process of changing the cat and not fixing the root problem will surely destroy the new converter quickly, and to make matters worse, that would not be covered under warranty.
      now
      as for where to buy direct fit ones (oem style, from headers back to end of cat where it meets the catback portion of the exhaust) for cheap-
      some ideas for you as most of these are 300$ at most. compared to the 1100-1200+ from bmw
      and personally this is what im doing to one of my e30s soon rather than cutting the pipes and putting a cheap one on)
      hope that helps :)
      Present:
      1984 633csi
      1985 635csi
      Past:
      1991 318i / 1987 325e / 1988 325is / 1986 325i / 1985 535i
      • reelizmpro
        • 9558
        You do not need to replace the entire cat with downpipes and flanges. You could simply have the muffler shop cut out the cat and weld in aftermarket Catco or Magnaflow Carsound cat. Both are high flow cats with 5 year warranty's I believe. You could find these universal cats for less than $100 too.
        If you want to stay OEM, you could try to find cheaper OEM ones thru parts suppliers or gamble on a used one from another ETA.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
