Steering play
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    Steering play
    well lately I've noticed that my steering wheel has been getting a lot of play, I can move turn it left to right without the car actually turning. it's maybe only a few degrees of turning before it actually turns, any ideas on how to fix this, and what's wrong with it? thanks
  • kencopperwheat
    King of Kegstands
    • 14396
    Have you inspected your tierods lately? Is your rack going bad?
    Originally posted by Gruelius
    • Sean
      • 5793
      Check the tie rods, 90% chance that's what is causing it.
      - Sean Hayes
      • e30Matt
        • 5077
        There's a small rubber coupling between the steering column and the rack. Look underneath while a friend see-saws the wheel back and forth and see if that's the culprit. I've seen many a car have this coupling wear out and cause those symptoms.
        • kowalski
          • Jan 2005
          • 1791
          :stupid: :D
          • tonytony
            Knee deep in poopie
            • Jan 2004
            • 3498
            it's not the tie rods I've recently replaced those. I'll check the rubber couplings. Anything else?
            • kowalski
              • Jan 2005
              • 1791
              its gona be the rubber
              • clutterbucker
                • Jun 2004
                • 481
                Well my steering rack does the same thing. A few degrees of play, and a quiet clunk when the steering wheel actually connects to the tires.
                Is there any way to fix this coupling...can I replace it?
                - 2000 Audi S4 Stg 2 (sold)
                - house (bought)
                - 1997 Civic Hatch (shaky but driveable)
                - 2010 Sportster 1200 Forty Eight Ed. (vroom)
                - 1991 318is S50B30 (TBA)
                • kowalski
                  • Jan 2005
                  • 1791
                  yes you can replace it. check at a local auto parts store.
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    Go torque them back down.
                    Trust me.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • kowalski
                      • Jan 2005
                      • 1791
                      i didn't read the recently replaced part of that id agree check those and the nut that holds the adjustment. even if it is the rubber just to make sure its good and tight.
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        thanks guys, unfortunately it's been pouring down rain here everyday. Haven' had a chance to check it yet.
