Which thermostat is recommended for winter? Lower temp I'm guessing
thermostat for winter
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
You shouldn't ever have to change your thermostat temp. The engine is designed to run at a certain temperature. Keep it there, there's no need to switch it out based on weather.Comment
Problem is I remember changing the thermostat when I first got the car and I dont remember which temperature I chose.Renting my rear wheel bearing tool kit. SIR
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
this is what i meant to say when i said "higher temp." i mean "higher than the low temp thermostats people put in in their cars.
:|AWD > RWDComment
I'm actually about to switch my thermo to the normal temp for winter.
Just go to bavauto and get the OEM spec thermo.Me: "I can't wait to redline my car!"
Mark: "Didn't you just break a rocker arm?"
Me: "Yeah, I don't think I've learned my lesson."
Mark: "You never will."Comment
