My heater is not blowing hot air. (blower motor works fine)Can anyone tell me what to look for as far as troubleshooting? :?
Heater Problem
Is your car getting up to operating temperature? If not your thermostat is probably stuck open. If it gets up to temp properly, your heater valve might be faulty. Has any part of the cooling system been opened recently? If it has you might have air in the system. All of the above problems will cause poor or no heat.
Originally posted by bmwguru007Is your car getting up to operating temperature? If not your thermostat is probably stuck open. If it gets up to temp properly, your heater valve might be faulty. Has any part of the cooling system been opened recently? If it has you might have air in the system. All of the above problems will cause poor or no heat.
its most likey this. these go out often
Originally posted by randomtask37not to steal your post, but where is the blower motor located. and how do i get to it, is it easily accesable?
Originally posted by DaNJust be careful with the fans on it, they are real brittle, you have to move it around a little to find the correct postion to remove it, or you'll end up cracking it.
Also, i am having trouble getting the clip part on, is there a trick to doing this why is it seem so difficult.
The squirrel cage on one of the two blowers i have is broken the good one i have that i put into my car is now no good as the clip popped off soon as i was leaving the house and rubbed hardcore against the heater core. :evil:
