Drain Plug Won't come out help pls
  • rj1790
    • Jan 2010
    • 108
    Good Evening everyone, So today while trying to change oil I find that my Drain Plug in my M20 Does not want to come out. It cannot tighten or loosen up. I can turn it all day without accomplishing anything. I'm Starting to think my Oil Pan is stripped. Any Suggestions?
    Thanks, Ray
  • scottinAZ
    • Dec 2009
    • 1312
    yep, sounds like the pan is stripped. Try to get a screwdriver under the head of the plug and then turn the plug with a wrench, this will sometimes get to clear threads and help getting it out. for a replacement, get an oversized plug, most parts stores carry them behind the counter for these "oh shit" moments
    I saved 15% on my Bimmer parts by switching to ...
    • Kershaw
      • 11822
      more fire is needed.
      jk, can you turn it by hand? try to pull and turn until it catches. then use a wrench.
      AWD > RWD
      • rj1790
        • Jan 2010
        • 108
        I tried that no luck. I went to my mechanic and he's quoted me 600$ for a new oil pan and labor to install it. I think I'm screwed
        • ak-
          • 12422
          I think you went to the wrong mechanic.
          Try the first technique harder.
          1991 325iS turbo
          • b*saint
            • 3794
            vice grip it and pull down while turning.
            Ma che cazzo state dicendo? :|
              Vice grips pulling and turning should get the plug out. Then a Timesert to repair the threads in the pan (the pan need not be removed to install the Timesert).
              • rj1790
                • Jan 2010
                • 108
                I'm screwed, I guess I'm going for a new oil pan
                • Yakinho
                  • Feb 2007
                  • 650
                  Did you not read the two post above you?
                  • rj1790
                    • Jan 2010
                    • 108
                    Man that thing is stuck like its part of the car. lol. I've tried those techniques already.
                    • ak-
                      • 12422
                      Have your wife try.
                      1991 325iS turbo
                      • KennyT
                        • 542
                        Take a torch to it, or actually get your hands dirty and pull the thing out.
                        • Holland
                          • Nov 2008
                          • 7212
                          I would not think replacing the lower pan on that car would be difficult. I don't know how the M20 pan looks but the M10 one is quite easy to get to.
                          Originally posted by DEV0 E30
                          • dannyb
                            • Dec 2009
                            • 27
                            M20 pan is easy to take off if you have patience
                            • chadthestampede
                              • Jul 2008
                              • 3601
                              DRILL A NEW HOLE. no really.
                              Originally posted by LJ851
                              Feedback
