I found a place that can do the smoke test and is about half a mile away. Would that be the next step or is there something I can look at myself first?
325is surging idle?
Just went down and started looking at the vacuum lines, the first one I looked at had a small hole in it. I bent it a tiny bit to see how large the hole was and it just snapped off. I was unable to easily pull the remaining piece off of the fuel pressure regulator so I didn't try any more. Can I replace just that line (if so, what would I use to replace it & where could I find it) or do I need to replace the fuel pressure regulator on the right that it's connected to? It's the line in the third picture down in this post: http://forums.bimmerforums.com/forum....php?t=1287208
Yeah, but getting a nice snug fit is tough if you are buying that stuff from the auto parts store. See if you can find a european auto parts store near you.
But yeah, that leak means lots of other rubber bits may be in the same condition.
Inspect carefully!Comment
Just got back, he had a look at it and told me to clean a bunch of stuff (corrosion and whatnot) which I'm about to do. He also showed me that the crankshaft position sensor wire was going right next to the radiator fan and was frayed so I'll need to pick up a new one of those.Comment
For the most part it runs a lot better when warmed up. Any time I sit at a stop light for a long time the car will shudder/stall. Sometimes if I put it in park/neutral at a stop light and give it a little gas it doesn't stall. This morning when I took it out it was constantly bucking/shuddering/stalling and was losing power randomly. Earlier when I drove it about 20 minutes away to the mechanic it ran fine aside from shuddering/stalling when idling.Comment
You may wanna pop the cover off the AFM and clean the wipers.
CPS can not be the issue: car would just die.Comment
I picked up a CPS a little while ago and am going to put it in once I find a guide on that. That needs to be replaced either way, the wires were completely exposed. The mechanic I went to yesterday also suggested the AFM. He said I could bring it up after replacing the CPS if I was still having the problem and he'd help clean it out (i think he mentioned something about putting new silicone in it as well?).
Edit: He also suggested I pick up spares of the three things in the red circle (can't remember what they were). Where could I find those?
Going to be installing the CPS on Thursday, anything I should check before then? Since yesterday it's been running decently, gone about 75 miles without any problems aside from stalling/shuddering occasionally when idling. Although if I go into neutral when idling and hold it steady at about 1k rpm it doesn't stall on me.Comment
If the CPS wire is occasionally shorting against something, then it could be the problem. The signal voltage is very low at idle, and can apparently reach 100v at redline. it's possible that there's a small enough intermittent short to only cause occasional issues.
Ich gehöre nicht zur Baader-Meinhof Gruppe
Originally posted by Top GearJust imagine waking up and remembering you're Mexican.
Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
