Brake lights stay on after changing brake booster
    Ok the above explains it.
    Could the adjustment fork on the Booster have anything to do with my problem or is the switch sticking?
    Thanks for your input
    Barry
    It's the fork, you left it too short. The brake light switch has normally closed contacts, the end of the fork needs to contact the plunger on the switch to turn off the brake lights. I made the same mistake with my booster I was lazy though and just bent the bracket for the switch down so it made sufficient contact.
    '89 Alpine S52 with goodies
      Ok so if i undo the bolt that holds the fork can I turn it without taking the whole booster off? And if so do I turn the fork towards the front of the car. Ok so I need to turn it towards the inside of the car after a reread of your post. LMK
      Thanks, really appreciate your help
      Barry
        You don't turn the fork. The position of the pedal is adjusted by loosening the lock nut and turning the shaft that sticks out of the booster.
          OK that makes alot of sense. Thanks Jean
          Oh by the way Huntsville is a great place been there many times.
            Fixed thanks..
