Car takes longer to start
  • MrMatt2532
    • 24
    My 87 325is seems to be taking longer and longer to start and is combined with a annoying whining/squeal, something must be going bad. I don't have too much knowledge though, so what could be the problem. Thanks.
  • Jordan
    • 12916
    Check the tension on the alternator bent.
    https://mtechniqueabs.com/
    • bichmgnt
      • May 2005
      • 42
      Re: Car takes longer to start
      Is the whine coming from the area around the passenger seat? Your girlfriend is broken. Replace her and you should be fine.
      :P
      Steve
      Tomahawk -
      When you care enough to send the very best.
      • cthulu703
        • Oct 2004
        • 288
        If the whine is coming from the rear and right of you, it could be your fuel pump is failing.
        • bmp
          • Jan 2005
          • 81
          dirty air fliter?, I had this similar problem but after i cleaned the air fliter it seem to have went away, but then again i'm not a mechanic so i'm not sure.
          • Dominick
            • Aug 2004
            • 323
            i have the same issues. it starts all the time but its sounds "nasty"
            could it be that my flywheel/starter have chips or imperfections in the gears
            www.ThundaCats.com
