WTF.... How bad is this ?
  • drcrougeux
    • Mar 2005
    • 13
    Help.
    While driving my 1991 318IC, there was a sudden, total loss of power.
    Only sound I heard was a "whooosshh"....from the engine compartment.
    Safely coasted to a stop. Checked the engine bay. No water, oil or
    metal/rubber parts missing or laying around. Turned key. It cranked
    over, but no start.. Had towed to friendly neighbor (retired mech-but
    is not too familiar with ECU era stuff. He took a compression test
    and reported there was 'no compression in any of the 4 cylinders'...
    None !!!
    What happened to my bimmer ? Any clues ? :shock:
    many tks in advance...
    drcrougeux
  • bichmgnt
    • May 2005
    • 42
    If it was a 325 I'd say it was the rubber timing belt but yours should be made of chain. Do the valves move? I find it hard to believe there is zero pressure even with a blown head gasket.
    Steve
    Tomahawk -
    When you care enough to send the very best.
    • drcrougeux
      • Mar 2005
      • 13
      THE SAGA CONTINUES....WTF
      UPDATE.
      The crankshaft is turning.
      But there is no connection between the crankshaft & the engine/belting
      system.
      Again, no compression in any of the 4 cylinders. !!
      Many mech/tech are astonished by this. So am I.
      But the problem remains.... :evil:
      Will someone, please jump in here, and provide some first aid...
      This can not be such a rare occurrence
      drcrougeux
      • mcgrath
        • May 2004
        • 445
        are your cams turning? if they aren't then you have a broken timing chain.
        • drcrougeux
          • Mar 2005
          • 13
          UP-DATE.
          ALLO.
          The cams are turning.
          t/chain is tight and seems to be all there. no metal parts laying
          around.
          How to loosen the t/chain ? what is the techquie to remove the t/chain ?
          The Bentley book doesn't seem to cover my model. 91 318ic.
          Still searching for clues for the problem. Then, i'll need some answers !!!
          many, many tks so far.....
          drcrougeux
            • 34844
            buy a manual for an E36 318i.. basically the same motor, just different body. that should help you :)
            • DaN
              • 1265
              Re: THE SAGA CONTINUES....WTF
              Originally posted by drcrougeux
              UPDATE.
              system.
              Broken Crank?
              • e30Matt
                • 5077
                Pull the plugs, shine a flashlight in there and make sure the pistons are moving. If not, maybe a broken crank? Seems extremely rare though.
                • drcrougeux
                  • Mar 2005
                  • 13
                  UP-DATE !
                  ALLO.
                  I don't know what happened, but here's the results...
                  ruined c/shaft sprocket
                  ruined t/chain
                  ruined chain guides (2)
                  Plus other parts/supplies as needed to restore/replace to driveable
                  condition. Maybe $500/700 .
                  Seems as if it could have been much worse....
                  For now, I have a diagnosis. next, the surgery, then recovery..
                  Many tks for the info...
                  drcrougeux
                  • pig4bill
                    • Sep 2004
                    • 122
                    How is it possible it didn't eat some valves? How can the cams be turning, as you said?
                    • drcrougeux
                      • Mar 2005
                      • 13
                      SAGA CONTINUES....
                      ALLO, AGAIN.
                      YES. It did eat some valves.... 16 of 'em.
                      BTW. 8 of the valves cost 'round $ 48. each ...
                      This major detour is a expensive turn of events.
                      The better news is, that when finished, this blue beauty ought to
                      purr & humm. For way, many miles .
                      many 10-q's.
                      Later.
                      drcrougeux
                      • hamann318is
                        • 3382
                        Close, but not quite. There is a lot different between the two M42s. However, I would still recommend the E36 Bentley book.
                        The BMW 318 is back. With a vengeance.
