OBC fuel capacity "trick"
  • e30Matt
    • 5077
    I know pushing the 1000 and 1 buttons together displays the amount of fuel remaining in the tank, but is there any way to make this display in gallons? Pressing the changeover contact doesn't do anything... just curious.
  • DaveInLA
    • Apr 2005
    • 222
    Re: OBC fuel capacity "trick"
    Whoa, never heard of this. That's all I have to do, push the 1000 and 1 buttons together and it'll tell me how many liters of gas I have left?
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      Yeah, its not very accurate when you're almost out of gas. Mine never reads below 5 liters.
      Matt: You cant =\
      • e30Matt
        • 5077
        Matt: You cant =\
        Yeah, mine never reads below 6 liters, but the range is surprisingly accurate... ran it down to 2 miles the other day to get a bunch of crap gas out of my tank.
        • NC325iC
          • Mar 2004
          • 6565
          id be way to friggin scared to do that
          • Brew
            • 3060
            And into your fuel filter, lines, and injectors?
            '91 318is
            • e30Matt
              • 5077
              Crap gas = low octane... I was low on cash.
              • Brew
                • 3060
                Ahh, I see. Thought you meant the sludge and dirt and shit that collects on the bottom of many gas tanks.
                '91 318is
                • bichmgnt
                  • May 2005
                  • 42
                  If you think that stuff doesn't get picked up anyway regardless of the amount of gas in the tank, you are mistaken. The pickup is in the bottom of the tank and that stuff gets stirred up every time you drive with anything but a completely full tank, especially if you drive hard. Maybe more of concern is the fact that the fuel pump gets hot and receives no external cooling from the gasoline when the tank is that low.
                  Both my computers act different when they get down that low. On one car the light comes on when I get down to about 40 miles left and goes down to 10 when it runs out of gas. On the other car it gets down to 22 miles when the light comes on and then it climbs up to about 35-40 miles and counts down to 10. At that point it blanks out with the car still running. Did this only once and went about a half mile to the gas station and filled up so I don't know how much gas was really in the tank but I think that was close enough.
                  Steve
                  Tomahawk -
                  When you care enough to send the very best.
                  • Brew
                    • 3060
                    Hmm, I guess its just a myth. Thanks for explaining it.
                    '91 318is
                    • bichmgnt
                      • May 2005
                      • 42
                      Well, as far as the hot pump issue goes I'm not so sure that isn't a myth as well. I've heard it repeated many times but have driven with the tank near empty just as many times with no problems so I don't know how true that really is either.
                      Steve
                      Tomahawk -
                      • george graves
                        • 20003
                        My car gets poor performance when the take gets too low...think it starts sucking a bit of air maby...
                        Originally posted by Matt-B
                        • bichmgnt
                          • May 2005
                          • 42
                          Weird. Mine drives great until it dies. At least the one does. I've never run the other one out but it seemed fine even when the computer blanked out.
                          Steve
                          Tomahawk -
                          • Mystikal
                            Wheel Fitment Expert
                            • 9602
                            Metric system owns you.
