Spent some time this morning at the BMW garage, had a tech throw them in for me (yeah, I'm lazy and usually incompetent).
With the MarkD 93 and K&N cone on the dyno, I could see the stock injectors were both tired (299k kms) and realistically not able to handle the demands of the software. There were still solid power gains throughout the rev band, but the A/F curve obviously showed that the car was asking for more fuel, and the weak injectors just couldn't deliver.
The car started immediately after the swap; no eta regulator, no software change, no changes made. With the 17.5lb Design II injectors, the car fired up immediately and idled perfectly. I know a lot of the guys who swapped to 19lb ones had a little ECU self-adjusting going on with the inherent roughness.
I expected the 4000-6000RPM range would get a slight boost now, since the car is getting the amount of fuel the software is requesting. But as soon as I pulled away from the shop, the difference in torque and throttle response startled me. In any gear and at any RPM, the throttle feels completely different; it's significantly more sensitive and responsive. I proceeded to beat the snot out of the car all the way home, and the torque gain caught my attention every time I floored it, and the power above 5500 didn't go relatively limp like it used to; the car is actually worth revving above 6000 now. Overall this mod did significantly more good than I expected it to, I honestly wasn't looking for much of a palpable difference in power.
Anyways this is just another friendly reminder that if you mod ANYTHING on an M20B25, you really need to swap those puny stock injectors out for something bigger. A lot of guys go for the 19lb Mustang ones, but don't bother; you won't need that much fuel, and you'll need to make sure that you find Design-II 4-pintle ones. All of the M50/S50 injectors are 4-pintle, and there are LOTS laying around the forums from guys who upgraded to 3.5" HFMs and whatever the hell else E36 guys do. I will revisit the dyno for some hard numbers once Mark D'Sylva gets this local one up and running, I'm really curious as to what I'm making now.
