Engine oil light stays on
    checked the oil level and its full; any reason light would come on and stay on? is there a switch somewhere I could check?
    help would be appreciated. Thx.
    Which oil light is on? The one in the check panel or in the cluster?
    The oil light in the check panel is driven by the level sensor in the left side of the oil pan. The cluster light is driven by the oil pressure switch on the right side of the engine. If that light is the one on you shouldn't run the engine until you know whether the light is on because the pressure switch is bad or if it is on because the engine has no oil pressure.
      Well the car runs like a champ...there is no shortage of power which only tells me the pressure is up! But thanks for the heads up -I'll find out which one it is...thanks.
      Ernie
        I drove my e30 on low oil pressure.. Once.
        Past: 1987 325iS, Bilsteins - HR Sports
        Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
        2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
          There is no problem with oil pressure. Car has 205k that is kilometers and recently added a rebuilt head. motor is super clean.
            mine did the same i thought it was a bad switch, i ending up resetting the service light and it turned the oil light off as well, give it a try. you just have to jump two pins together in the scanner plug and have the ignition on or something i dont remember exactaly just google it it took me a whole 10 seconds to find it last time haha
            hope it works if not probably the switch
            IX being restored here
            Ix turbo build here
              Engine ground taking a dump can also piss it off
              Check Us out on Facebook
              Full Product Line Tuning
                the dummy said his oil level was up and it wasn't..sheesh.... would explain why the oil light was on...DUH!!!
                It's pin #7 to ground this resets the oil service and inspection 1,2 light.
