wiper nozzle problem
  • Ceeker
    • Sep 2009
    • 2821
    Up ti'll yesterday my wiper nozzles worked fine. now I only get a trickle from them. I thought maybe the pump packed it in so I changed it and still does the same. the nozzles are fine/heated.
  • KillaCams
    • Mar 2008
    • 998
    Check your washer fluid lines one of them probably broke or disconnected somewhere
    • Ceeker
      • Sep 2009
      • 2821
      no leaks present.
      • Carib
        • Aug 2011
        • 28
        More than a year later.... what was the cause of your problem?
        I'm about to investigate the same issue with my washer nozzles as I'm also getting just a wee trickle out of them. Initial investigation found no leaks. Going to continue tonight.
        • bmwguy325is
          • May 2011
          • 1263
          Check the pressure check valve its on the top of the hood when it open
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • jeffnhiscars
            • Jun 2011
            • 6011
            If you are not careful waxing, they plug easily...just saying
            Alice the Time Capsule
