Temp Gauge not working.
  • kencopperwheat
    King of Kegstands
    • 14396
    When I turn the key so that all of the electronics are on (I'm not sure of the technical name for that position), the temp gauge works fine. But then when I start my car it immediately falls. Is this a ground issue? It doesn't happen all the time, but probably 75% of the time.
    Originally posted by Gruelius
  • bmwguru007
    • 561
    Check the temp gauge sender, it's located at the end of the fuel rail and should have a brown tip. The temp and fuel gauges have nuts behind the cluster that can loosen over time and can cause these types of problems. Otherwise it could be a trace in the cluster or maybe the SI board or batteries. But check the first two before you get into that.
    • kencopperwheat
      King of Kegstands
      • 14396
      how would i check to see if the temp gauge sender is good or not?
      • BahnE30
        • 1050
        hit the dash above it until the neddle jumps it should then begin to read the temp
        Note: just a temporary fix
        fix this asap as you could end up heat seizing your motor and not know it until it's to late
        • kencopperwheat
          King of Kegstands
          • 14396
          This would tell me if the gauge is not grounded correctly in the cluster, right?
          • bmwguru007
            • 561
            Unplug the connector with the ignition off. With the car off and the ignition on use a piece of wire to ground the terminal of the connector against something metal in the engine compartment. The gauge should move up, if it doesn't the sender is probably faulty. If after replacing the sender the gauge still doesn't move, the wire to the gauge and/or the gauge itself is faulty.
            • kencopperwheat
              King of Kegstands
              • 14396
              Which end of the fuel rail is it? The end toward the front of the car? Would it still be brown if I have an M10?
              • kencopperwheat
                King of Kegstands
                • 14396
                (Hitting the dash above the gauge did nothing, by the way so I'm assuming that it isn't a grounding problem in the gauge itself)
                • bmwguru007
                  • 561
                  I don't have much experience with the M10, but as far as I know it should be at the front end of the fuel rail. There should be two sensors in that area that look identical, but are different colors. Of these two sensors the one for the gauge has a single terminal. The other sensor has two terminals and is for the fuel injection system. You'll have to unplug the connector to the sensor to check this.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Well, it was the temp sender. I took the old one out and it was NASTY. I think they're made of brass or something because my new one was really shiny, but the old one was brown. Five minutes of labor and problem solved!
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      Problem NOT solved... damnit. I replaced the temp sender and it still doesn't work all of the time. When it's not working I can hit the dash all I want and it doesn't budge. My mechanic said that the circuit board may be faulty.
                      • nickmpower
                        • 82
                        Mine is having problems too, it goes up a little when it is powered up like to the begining of the blue but then stays there even when the engine gets hot. I switched the cluster and it still doesnt work. I tried touching one of the 3 wires that connect to the sensor to ground and it still doesnt go up. I tried seeing if there was continuity between any 2 of the 3 wires and nothing. What could be the problem? the wiring? if so is there anyway i can by pass it? after i first got the car together i noticed it moved a little but then didnt move again.
                        does anyone know in what order the wires connect to the sender? i took one off to try and clean it and they all came off! i think ther is a green and a black and brown and black? and a black
                        • kencopperwheat
                          King of Kegstands
                          • 14396
                          3 wires? I think you've got the wrong sender. The coolant temp sender has a brown top and has 2 wires going to it. Or does the M20 one have three wires for some reason?
                          Perhaps your sender is faulty. Or maybe the wiring?
                          • nickmpower
                            • 82
                            i have an m42 so maybe the same touch it to negitive wouldnt work
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              Have you replaced the actual temp sender?
