I finally replaced the missing fogs on my 87 Eta, and found something interesting. I have a duplicate connector under the left headlight that is the same as the fog connector (c 126). Does anyone know what this connector is for, and what it is supposed to connect to? I dont have any other loose connectors floating around, and it is NOT for the OBC temp sensor.
unknown connector???
ok, I have the same connector on mine and wondered if this was for the fog lights. you now have confirmed this. the one I located was behind the drivers side headlights. So then my question to you is where is the connector located which you used for the fogs? lol
perhaps the additional connector is for another aux option?sigpic
Originally posted by scottinAZ View Postit was in the same area, has yellow/brown and brown wires going to it. the one in queston here has black/red and brown going to it. still no clue what the hell its for??
See if someone can get a headlight wiring schematic on here. that should show any auxiliary plugs.sigpic
Originally posted by scottinAZ View Postdidnt see anything on the ETM that would match the connector.sigpic
Originally posted by scottinAZ View Posthave factory ac and aux fan connected, so this isnt that connector. as for Rally lights, I suppose this is a possibility, but where do they get power from. this connector was DEAD with the switch on, and does not appear to be grounded either. the mystery deepenssigpic
