Bleed screw on the radiator broke
  • PeaveyBassist
    • Sep 2004
    • 3511
    When I changed my timing belt, we took the radiator out and when I went to turn the screw on the bottom driver's side to drain all the coolant, the plastic screw just snapped. So now its stuck in the radiator. Is there any "easy" way to get this out? I wanna replace it with a metal screw because the plastic one sucks balls big time. Any ideas?
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • arsevader
    • May 2005
    • 1025
    Drill her real careful then maybe try cuttin ginto it with an exacto knife.
    The threads it screws into are plastic as well.
    I would empty the rad first with the lower hose of course. ;)
    Dunno if a metal one would be a better idea though because of the plastic threads.
    James
    • PeaveyBassist
      • Sep 2004
      • 3511
      Hmmmm... I wouldnt think I would need to replacet the entire radiator just cus of this little problem. Maybe with the radiator out of the car I could drill a hole just slightly smaller than the plastic screw and get a new plastic screw. Then try to thread in the new plastic screw and see if it taps itself? Or I could use a tap and tap a new hole for the screw. Any ideas from others on metal vs plastic screws though?
      Will
      DaveCN = Old Man
      • arsevader
        • May 2005
        • 1025
        I don't think it's that drastic yet. But you do need to be careful witht eh plastic. You might want to remove the rad to give you some more room to work.
        James
        • PeaveyBassist
          • Sep 2004
          • 3511
          I'll definitely take it out. Its so easy to take it out. 2 hose clamps, and 2 bolts :) Then it lifts right up.
          Will
          DaveCN = Old Man
            • 34844
            I had the same thing happen, it's not too hard actually. get a small screwdriver (or some other metal, pointed object with a handle) and a lighter. heat up the tip of the screwdriver (make sure it's HOT), and stab the plug with it. once it cools you can just unscrew it. no removal of the radiator neccesary. :)
            • PeaveyBassist
              • Sep 2004
              • 3511
              Wow Nando. I'll have to try that one :) Are you basically just trying to melt the plastic to the screwdriver or something? lol Thats a REALLY good idea!
              Will
              DaveCN = Old Man
                • 34844
                yeah, but it has to be a pretty small tip, a big fat phillips probably won't work, a flathead or centerpunch would be better. in any case, it was really easy to unscrew once I had the thing melted in there. I heated up the end for about a minute before I stuck it in.
                • pig4bill
                  • Sep 2004
                  • 122
                  That is a great tip. Stuff like that should be kept in a wiki or something similar.
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    Yea, I was plannin on using a flathead. I guess I should use a small one. We have a propane torch. I'll prolly just use that. Should I just get a new plastic screw from the dealer? Or should I find a metal/brass screw that has the same threads and stuff?
                    Will
                    DaveCN = Old Man
                    • bmwguru007
                      • 561
                      Just get a new drain plug from the dealer, a metal plug and the plastic threads in the radiator aren't going to mix well.
                      • cahomey
                        • Mar 2004
                        • 1201
                        the plastic one is fine. It has like 6,000 washers and shit on it, tighten it snug.
                        It's fine.
                        "It's like a koala bear crapped a rainbow in my brain."
                        R.I.P. Harry Goz aka. Captain Murphy
                        "My ride, My ride, she don't beg, steal, cheat, or lie,
                        My ride, My ride, and our relationship is classified."
