? about hose connections
  • cccp
    • Dec 2004
    • 15
    This is for an 87 eta
    Anyone know where the breather hose connects to? The one the comes from the valve cover, Its about a half inch in diamater. I'm thinking it connects to the right side of the throttle body, to the opening adjacent to the two cooling openings. Thats the only place I can think of, however in order for it to fit there i really have to contort it.
    Also does it matter which order I put in the for the coolant in the throttle body, I ean if I put the hose that was originaly conneted to the upper opening in the lower opening? And vise versa. Thanks.
    Edit/Delete Message
    • 34839
    it connects to the throttle body, right where you suspect. it snakes underneath the intake manifold.
    also, I don't think it matters too much which way you put them, but if you buy the factory hoses they won't fit as well on the wrong side.
