Wiring Map Light R/V Mirror To Door Pin.....
  • D///M3
    • 83
    Has anyone wired their R/V mirror w/ map lights to the drivers side door pin switch? Idea is that the map Lights would stay lit/ on until door is closed (or if the light delay relay is working - 5 seconds-or- until th key is turned on)-
    Would be a nice feature instead on "just" the standard "on-off" lighting-
    I have a Map Light mirror to put in my 325e- just wondered if anyone has acomplished this? :roll:
    '95 E34 525iT
    '88 E30 ///M3
    '85 E30 325e
    Ft. Lauderdale, FL
    http://members.aol.com/e30m3therealm3/fhm3.jpg
  • Bryson
    • 1490
    It's possible, if the power switch on the maplights uses ground to switch on/off (never opened mine). If it switches positive, it would be fairly tough as you'd have to use relays and such
    • Jordan
      • 12907
      Have you priced the Map Light bulbs lately? I'll use my sparingly thank you. Wired up like this, they would burn out quite quickly.
      https://mtechniqueabs.com/
      • Bryson
        • 1490
        I think they're $25, 17 retail or something like that, just replaced one last month and was extremely surprised
        • franco90
          • 3185
          update you can get bulbs for 7 dollars a piece from BMA from Patrick BMW part # is 63311375003 I order 4 that a steel .
          I've always been proud of being a Marine.
          I won't hesitate to defend the Corps
          "Supersquad"
          ‎"Prostitutes are a sub-category of Amusement Parks"-
