Torx on E30.
  • 5Toes
    • 9836
    Torx on E30.
    Are there any torx bits on these cars? Im buying tools today or tomorrow, and Im wondering if I need torx drivers also.
    Im buying tools mainly to work on my little honda (which is all hex and phillips), and my soon to be E30. If there are, what sizes are they?
  • e30rapidic
    • 2167
    yes, bellhousing....but not sure of sizes, check www.bmwfans.info
    '87 325ic, powered by S50.
    • 10Toes
      Me Father Was A Tree
      • Jan 2008
      • 61222
      Yes some fastners are.
      You will need male bits and female sockets.
      • mamzak
        • 883
        The front bumper requires a T-55 torx
        All girls fuck but not all girls fuck around with combustion engines.
        • FredK
          • 14763
          There's a handful of torx fasteners.
          Security torx:
          Airbag impact sensors
          Internal torx:
          Airbag to steering wheel
          Sunroof to sunroof rails
          Bumper bolts (T-55 OR hex 10mm, check first)
          External torx:
          Transmission bellhousing bolts
          • 5Toes
            • 9836
            So not that many encountered unless you are swapping engine or bumpers.
            I dont need them then
            • 5Toes
              • 9836
              What sizes though. Im just curious
              • Wh33lhop
                • 11705
                Even then, I was able to use a simple 6-point socket to get the male torx head bolts out of the bell housing. Would have been nice to have the proper tool though.
                paint sucks
                • lolcantturn
                  • 4588
                  If I'm not mistaken, E30's PRODUCED in 1988+ M20's came with Torx head bolts. My 88 E30 that was produced in late 1987 did not.
                  Originally posted by TSI
                  OEM+
                  • AbsorbantNut
                    Non faccio funzionare questa merda
                    • Jun 2010
                    • 2491
                    You most likely wont need them. If you do, they will be the ones FredK said.
                    And there are some on the fenders where they attach to the valance.
                    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                    • jclar
                      • 265
                      You need a T-50 torx to get the camshaft sprocket off. The only one I've encountered as far as I remember.
                      '86 325es M50
                      • txtorquemade
                        • 1758
                        I find I need them. Cant recall what for exactly but Ive used them for sure. Hex and torx.
                        sigpic 1987 325is
                        • FredK
                          • 14763
                          oh yeah! I forgot about those. They're like T-25 or so.
                          • rThor432
                            • Feb 2007
                            • 3907
                            I would recommend having them in your tool set regardless. You never know when you might come across them and you don't want to play around trying to remove them with a hex socket hammered over the head or a small flat-blade screwdriver into a female torx head.
                            I'm thinking E10, E12, and E14. 4 E14's, 2 starter bolts are E12's, and some BMW transmissions have random E10's scattered around. Can't remember if the E30 does for sure or not without looking.
                            • polg0003
                              • Dec 2018
                              • 1
                              Thank you
