Speedometer pooped itself
  • mjc85
    • Mar 2004
    • 164
    My speedometer sometimes stops working, but when i tap on the cluster it comes back. It has lead me to think the plastic gears behind are worn out. Can anyone confirm this ? And where can i get new gears ?
    1990 318is Brilliantrot
  • Surge
    • Dec 2004
    • 44
    I've got the same problem, Check the ground - grounding the speedo wire (from somewhere near the dash) onto a piece of bare metal can temporarily fix this issue.
      • 34839
      if you tap it and it comes back it's probably just the ground connection.
      • AdamF 88iS
        • 2051
        The 'broken gears' refer only to the odometer. You have an electrical issue, not a mechanical issue.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • Court M3
          • Jan 2004
          • 6713
          check the connector on the back also. Mine is missing the black clip on the back every so often if I hit bump just right my speedo will stop working
          Continuous For Sale Thread
          323i s50
          • e30Matt
            • 5077
            Could be a broken trace on the PCB also... my tach cuts out like that a lot and that seems to be the only cause left that I haven't checked.
            • marinf23
              • Oct 2004
              • 54
              i had the same problem and it was as easy and re-soldering some of the bad joints on the back. I re did mine and now the speedo works great.
